M50d-r1 Scratching noise
bndpoper
jasper, Tennessee, United States
Hello, first post. 98 Ranger 4.0 4x4 196000 miles. My transmission has started making a scratching noise in any gear (including Neutral). Here is a video.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
Does it have any oil in it?
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Did it happen after you changed the fluid?
bndpoper
It had been sitting for almost a year with a bad slave. It was doing it some before it was parked, but not as bad. I pulled the cover while it was out, and did not see anything wrong, or hear anything working it by hand.
Junk Collector
Truck of Month
4,800
Rapid City SD
Sounded to me like the noise went away for a bit, did you push the clutch pedal in? I wouldn't be real worried about the transmission itself making that noise, sounds more like a throwout bearing or pilot bearing noise... I'm assuming you replaced the slave cylinder recently?
