M50d-r1 Scratching noise
bndpoper
New member
jasper, Tennessee, United States
Hello, first post. 98 Ranger 4.0 4x4 196000 miles. My transmission has started making a scratching noise in any gear (including Neutral). Here is a video.
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
sheep herder
Well-known member
397
sheep pen
Does it have any oil in it?
Blmpkn
Active member
162
Southern maine
Ford ranger
2.3
Did it happen after you changed the fluid?
bndpoper
New member
It had been sitting for almost a year with a bad slave. It was doing it some before it was parked, but not as bad. I pulled the cover while it was out, and did not see anything wrong, or hear anything working it by hand.
Junk Collector
Forum Moderator
567
Rapid City SD
Sounded to me like the noise went away for a bit, did you push the clutch pedal in? I wouldn't be real worried about the transmission itself making that noise, sounds more like a throwout bearing or pilot bearing noise... I'm assuming you replaced the slave cylinder recently?
