LS 400 LEXUS ENGINE (1UZ) IN A RANGER SWAP?
fastpakr
2,832
Roanoke, VA
Cool. Good enough for me! I don't have any VG experience (at least that springs to mind), but I had an '01 QX4 with a VQ for a few years. Always impressed me with how well it did, and a friend still owns the vehicle. Last I heard it was around 300k.
NIGERIAN RANGER
28
Lagos, Nigeria
I was thinking about doing a k series like a k20 turbo or a 1uz in my ranger also there is a YouTube that goes by the name NIGHTRIDE they are doing a 1uz swap in a Miata so I’m sure that it’ll fit in a ranger;missingteeth;
How would you fit the k series Honda engine? Would it fit perfectly for a rear drive platform?
I wished someone has tried the 1uz swap.
NIGERIAN RANGER
28
Lagos, Nigeria
Yes, I'm in the process of buying a couple cars with them in them. And yes thats the SOHC version found in 80s 300zx, hardbody pickups, pathfinders and either maximas or altimas. Some were NA, some supercharged and some turbocharged. Most were 3.0L, pathfinders are 3.3L. Fairly easy to make good power with stock bottom end.
I have also thought about the 3.0l engines Nissan used in their pickup trucks. Was just wondering if it'd fit in a ranger without much modifications.
Dezerttaxi
5
San Diego
1989 Ford Ranger, custom frame rails and suspension from the front of the cab fwd, 1UZFE with a M122 supercharger on top 8psi nets around 333whp and 338fttq. Has a MegaSquirt II stand ECU its mated to a TH400.
Robertmangrum.rm
Wannabe Overlander
1,610
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
That thing looks awesome. Nicely done
NIGERIAN RANGER
28
Lagos, Nigeria
Could you share some experiences here pls?
What problems did you encounter with this engine swap?
Dezerttaxi
5
San Diego
Google supercharged 1UZFE Ranger there is a write up on a website called engineswapdepot. We had issues with cooling as well as making transmissions survive. After a few C6s and C4s a bell housing adapter for a Th400 solves the issues.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
For that level of off-road.....I would be using a ried case too .. worth the money
NIGERIAN RANGER
28
Lagos, Nigeria
Another problem i think i may encouter is, how does one modify the transmission shift to fit a ranger? On the 1UZ, and other Asian vehicles, the shift level position is not at the steering location, but floor. Asian vehicles that have had their shift level at the exact points where ford has had them, is Nissan quest, of the '90s.
So question now is, can floor (flour) positioned transmission shifter be modified from any vehicle, to fit a ranger or ford kind of steering positioned shifter?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I have seen and done a few shifter swaps. I swapped in B&M floor shifter in my old bronco many years ago, it came with a universal shift cable. Compared to swapping in a v8 and transmission, this is a relatively minor modification.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
There actually is a removable floor plate that you can easily modify or make a whole custom piece easily. Look under the tunnel or pull the carpet back
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
You don't have to use a sawzall. Jigsaw or angle grinder w/ cutoff wheel are also options.
NIGERIAN RANGER
28
Lagos, Nigeria
After doing the floor plate thingy, would the steering shifter positioned at the steering wheel, be left like that?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
On my bronco I just left it there. I think eventually I disconnected the shifter rod from the column. It's all just mechanical connections. Very rudimentary compared to engine swap. This was 20 years ago when I was into hot rodding, not sure what's out there in aftermarket today. But you could probably find some cool stuff searching B&M or, Hurst or Lokar.
NIGERIAN RANGER
28
Lagos, Nigeria
Mehn, unfortunately, I'm in Lagos. Hot rodding isn't just common over here.
