low power, code 411
93rangemaster
All right, so far what's been done.
-cleaned my maf, tried a different one
-replaced tps
-replaced fuel pump
-replaced both cylinder heads with newer rebuilt ones, and all new gaskets due to a ruined valve seat.
-Replaced the exhaust, checked for a clogged cat.
After all this, truck is still missing some power, it almost sounds like it's missing... Starts and runs fine, idles around 900 sometimes and 700 other times though which is weird, and I'm getting a running code for a 411 "can't control low idle". Oh, and lastly, I'm also getting fairly bad gas mileage.
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
03ranger4x4
If the only code you have is the 411, I personally would start there.
Have you looked into the Idle air control valve? Somehow, this valve seems to get black crud on gummed up into it sometimes (Im not sure exactly why) Maybe yours is so bad that the valve is starting to stick keeping the ECU from fine tuning the idle speed and giving you that code. Try cleaning it, and then see if the idle is bad. Also, check for vacuum leaks. If your careful about it, you can use small propane torch to find leaks. Just have the propane bleeding out of the tip WITHOUT it lit and put it near hoses/connections where you think a leak may be with the engine on and idling. If it is in fact a leak, Typically the idle speed will increase as soon as the propane gas enters the engine. Always thought that was pretty clever, and it worked for me to find leaks.
After you get that code to clear I would move on to the other issues. If it turns out to be a vacuum leak, that might solve all your issues there, since air bypassing the mass airflow sensor will cause the engine to run poorly.
93rangemaster
Thanks for the reply, I have looked but have been unsuccessful in finding vac leaks so far. I was reading through some threads of similar situations, and ppl were thinking it could be cam pos'n sensor, crank pos'n sensor, or a loose timing chain. Looking and feeling around back there, it seems like my truck doesn't have a cam pos'n sensor, and the engine has roughly 210xxxkm(130xxx) miles on it, would the chain have stretched out yet. Crank pos'n sensor maybe? My confusion about the iac being the culprit is that I don't know if that could cause the lack of power I've been experiencing, I'll clean it out anyway though.
Thanks!
Kona
06/2014 OTOTM Winner
Canada Military - Veteran
Kamloops BC
4L ? Mine ran good @ 307, kms just a had a little issue from a cracked head due to a plugged rad no seemed to diagnose. These engines are known to suck in the fuel rail to manifold gasket creating a vacuum leak or as mentioned the Idle Air Control valve regulates air flow at idle... you can take it off and clean it or they are under a $100 to buy.
