Low/No Oil Pressure 351w
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
So I'm at my wits end here. I'm finishing up my motor swap and I've noticed my mechanical oil pressure gauge is showing no oil pressure. First thought was just some shit in the line from the swap. So the next though was loosen the gauge sender, so it would leak if it had pressure. Tried it but no luck, no leak. So I pulled the drivers side valve cover and tried turning it over. No squirting oil. Bottom of valve cover was slightly oily.
I had to swap oil pans and when I did I put a new standard volume oil pump in, thinking I screwed that up somehow. What I don't understand is I there's no oil pressure, the motor isn't noisy. It's hard telling with open headers though. Before I tear everything back apart, is there any other tricks I can try on this motor to verify the lack of oil pressure?
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Some oil pumps have to be primed with vaseline or pumped up by spinning the pump with a drill
Mickey Bitsko
Pagosa Springs CO>
live everyday like your gonna die tomorrow
96Indyram
15
Clearwater Ks
2.8, 2.9
^ that
pull the distributor, go to autozone and borrow the priming tool. stick it in there and spin it up..I think reverse rotation on drill.
Then ...if no oil still, you will have to pull the pan and see whats going on.
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
So even though I've ran the motor 5-8 minutes it still hadn't primed? Ok I'll try the drill primer. Thanks
8,370
Make sure to mark the distributor and rotor before pulling it, no need to make a job harder than it needs to be.
You could have had pressure at startup but it is gone now, which is why there was no "noise".
Could be high pressure by-pass valve opened and then stuck open, so oil pump is just pumping oil back into the pan.
I would pull off the oil filter, put a pan under housing and crank engine or use drill.
Could simply be a bad filter.
"New" no longer means "it works", "new" now means "never tested"
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Figured it out after priming and priming and priming.
Got the hoses backwards on the oil filter relocation ;brownbag;
So after that I have awesome pressure.
Also think I put the dizzy back in a tooth off.
Thanks for the helpful answers
TexasRebel
5
Texas
Ford, Nissan
4.0 in both
You live every day, you only die once...
At least it was something that easy to fix/redo and not something where you would have to pull everything back apart. We all make stupid mistakes at some point, just some realize it sooner than others.
