For Sale Lots of 1987 Ranger steering/suspension parts FS, NIB Pics added
corerftech
84
Memphis, TN
Updated 01/11/2023, 8:00 PM CST
So folks I have beat in many people here for help/thoughts/suggestions for my 87 V8 swap particularly in the “make more room under hood” aspect.
I ordered to rebuild the entire front end (and the rear too) many parts from RA and other sources. Rod ends, drag link, steering box rebuild kit, bushings, NEW fuel tank, a bunch of stuff.
Well to put it mildly, I pulled my balls out of my wife’s purse (and a few bucks) and have bitten off not only a Mustang 2 front end but as well a full front end frame widening all the way back to the cab backwall. All for the sake of long tube headers, smoother ride, more blower room, weight reduction.
So…. I need to unload some parts.
As well by Jan 10th I’ll have the frame separated in full from the back cab wall forward. I need it for takeoffs (measurements) but otherwise their is a a very tight steering box, coils springs, radius arms, etc, rust free (not free rust, Alabama car), etc. There is also an entire blue dash available (entire!!) as I am just building a bare min dash for a few gauges. Gauges are perfect, nothing damaged or broken and the wood grain plastic is excellent.
I need room to lay out the new front clip frame and this stuff is in my way.
I’ll post pics and part numbers that can be referred back to Rock Auto and figure a 10% reduction from Rock Auto prices.
The only other offer is that if someone needs a really clean 1987 std/std rolling frame (tires and wheels stay once loaded for transport), please let me know. There is so little of the frame left, it would probably be easier to build the whole frame in total.
Any interest in the frame, please speak up ASAP. Before a 4 inch wheel starts to spin!
There will be an automatic steering column/pedal support as well, converting to manual from auto. It’s ready to pull so if you need it speak up.
Auto floor shifter.
2.3 ECU (auto)
The 7.5 open rear is also avail (if the frame gets cut, if not then it is part of rollingframe).
If your in the Midsouth, or near Memphis, let me know.
Dash/rear end parts priced as follows:
Whole dash, $75.00 plus shipping
Rear End: $75 local pickup (hub to hub, shocks e-brake cables)
AC parts only: (everything that a ranger needs inside the cab, ducts, controls, cables, diverter box $45.00 plus shipping.
Sorry Im slow at gettng pics and prices up. If I only had more room..... and I will if someone takes some parts off my hands.
corerftech
84
Memphis, TN
Update:
7.5 trac loc differential is spoken for
7.5 diff overhaul kit as well (RumPunch, 12/22)
a 7.5 TL clutch pack is avail if you need to freshen your track loc diff.
Also a very clean 7.5 inch 3.73 ring and pinion is available, removed from the TL diff.
I have a donor housing (7.5) that has drum backing plates and axles available, all in nice condition.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Bought the 7.5 parts from Corerftech. Excellent interaction, some great conversation, quick and QUALITY shipment and exactly as described. Awesome and thank you!!
svtcards
137
Lyman maine
302
3'' front 4''back
corerftech
84
Memphis, TN
Negative, that is the 1987 OEM dash carcass. Has a nice crack in the midline but else is in pretty wholesome condition.
PlumCrazy
2014 Truck of The Year
168
Millersport, OH
Solid Axle Swap 4x4
How much for this bracket shipped to 43046?
Bobber64
49
Brooklyn Park, MN
Do you still have the automatic steering column? I am swapping in a 302 and converting to an automatic.
corerftech
84
Memphis, TN
Bobber64,
that year is floor shifted.
I have the whole shifter but …… it’s the OG floor unit. Nice condition.
JerrySab
43
Los Angeles
Hey guy!
Have a windshield wiper lever by chance?
corerftech
84
Memphis, TN
JerrySab, I expect your either after the "windshield" wiper gear train inside the cowl or the electric wiper switch.
But you didnt say switch so I am expecting machine parts, from motor to wiper blade. In any case, wipers are ready for deletion on this cab and Im happy to send pics.
if your after a switch, mine is not a candidate. Its gunky, sluggish and Ill still need it for turn signal duty.
Plus a new one on Amazon is less than shipping from Tennessee.
Send me a pic of the parts if you can ID them and Ill bounce my pics back.
Mike
corerftech
84
Memphis, TN
I have a NIB 7.5 Trac Loc clutch pack avail for sale.
If you are planning to freshen your 7.5 TL clutch stack, please reach out. Heretofore If I have a 7.5 that needs posi, Ill be adding a mini spool instead. I also have ball joints and front suspension parts (energy bushings), I uncovered a pair of Monroe rear shocks I didnt realize I had, tie rods, steering arm and a power steering rebuild kit.
If you need a TIGHT OEM steering gear (PS), the blue truck has a goody......coupled with rebuild kit....would be very nice.
NakedDucks
63
B’ham AL
I’m going to assume this is a 2wd truck?
