Loose gear shift lever
Daveyboy1982
Donkeypoop1
Ford ranger
I know this is probably a very common post or problem but I just bought a 2011 ranger and noticed that the gear shift lever is loose and I've checked the common loose torx screws and they seem to be tight so from what I've read I should probably check the gear shift lever bushing which is the orange bushing at the end of the lever, just wondering how hard that is to get to and how hard to replace and it is shifting gears just fine just alot of play in the lever any help would be appreciated thank
rumblecloud
1,120
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
If you're location is any indication of the types of roads you travel, the shift - and I use that term loosely - bracket and linkage on the trans may just need a good cleaning.
rumblecloud
1,120
48022
Ranger Splash
Stock
Daveyboy1982
Donkeypoop1
Ford ranger
Yes I did the bushing at the end of the shift lever was bad I replaced it and it's good to go now
