Looking for longer shackles
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
My 93 was lowered when I bought it, being a frugal Yankee, I left the dropped I beams in place and swapped the spring perches on the rear end so it sits on top of the axle. The problem is that the rear is 1 1/2 or 2" lower than I want, even after new rear springs. Has anyone found any longer spring shackles? I don't like my rear end sagging nor do I want to hear :that's to be expected for a man your age. See that? As a public service I supplied my own smart ass reply.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Check out this from the Tech Library...
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
Thanks. I had found some but they're only listed for 98 and newer.
JOLENE_THE_RANGER
204
long beach, ca
all shackles are the same any year will fit. have ya thought of a quick google search for ranger lift shackles?
Junk Collector
Truck of Month
4,797
Rapid City SD
Belltechs will fit any year. They will change your pinion angle though.
What about add-a-leafs? Or load leveler shocks? I put a short add-a-leaft set in my Explorer and got half an inch of lift... a set of Monroe load leveler shocks lifted it another 2". Rides nice although it's a lot heavier than your truck.
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
That is not a public service. You deprived us of some fun.
no worry. We’ll find something else.
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Put in a 2" block? Between axle and spring.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Reads to me like spring over axle...
Do you have a 10 or 20 ton press? Re-arch the springs your self.
But the shackles everyone are talking about should do the trick.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I installed a pair of Belltech 6400 shackles yesterday and gained 1 1/2- 2 inches, just what I was looking for,thanks.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
That's better than Viagra. :yahoo:
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Got before and after glam photos?
Isn't there two sets of holes on those and which holes did you use?
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
I used the holes that gave me the most lift. I'll have to take a new picture now that it isn't a tail dragger anymore.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
A couple weeks ago I replaced the 2+1, 1100 lb springs with 3+1 1250 lb upgrade springs with no change. Then I swapped shackles,Here's before and after photos:
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Those did the trick pretty well...
