+1 ^^^^
Welcome to TRS
1998 Mazda 3.0l (B3000) automatic
What were original symptoms?
If crank sensor is bad engine would not start, ever
Cam sensor issue can cause rough running, but so can a host of other things
Cam sensor issue WILL turn on CEL(check engine light) and set cam sensor codes
In 1998 you should have a 3 wire cam sensor, 1999 and up used 2 wire and they are NOT interchangeable
If no CEL then you have a mechanical issue, not a sensor issue
3.0l Coil Packs did have issues
Pull out spark plugs and have a look at the tips, see if they show Rich running or oil burning issue
Coil pack spark plug wires are easy to mix up
3 4
2 6
1 5
Those are the
matched pairs, 3/4, 2/6, 1/5 on the coil pack
So NOT
3 6
2 5
1 4
How long have you owned this vehicle?
How long has it been "running fine"
Anyone can get "bad gas", and at anytime, has a high water content, so engine is running fine and you fill up and then a day or two later engine is running poorly, "what the heck???"
Simplest explanation is often the correct one, so don't over think things
