Location of 4.0L Gauge Temperature sensor (pictures)
Observer
New member
For your consideration: The location of gauge sensor for engine temp.
On 1992 Ranger 4.0L 4x4 supercab.
Manual has no info on where this thing is so I was looking in all the wrong places. Hope it helps future people. (Hello future people!)
Took the single wire off, shorted to ground and needle went to max- bad sensor. Likely just crud buildup.
Good, no electrical problems! :icon_thumby:
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
Observer
New member
Out with the old- in with the new!
The gauge now works, but it never quite makes it even near the middle.. Maybe time for a new engine soon too as this one has pushrod tick to the extreme.
Any suggestions about that? Keep with the 4.0 or something else?
Earl43P
Well-known member
36
E-City, NC
Try installing a new thermostat.
$8 well spent, since it regulates the temperature of the coolant that your new sensor is reporting.
If you don't want to spend the $8, slap a piece of cardboard in front of the radiator for a short drive. If the temp climbs higher, you can replace the thermostat with more confidence that it'll help.
4x4junkie
Forum Moderator
252
So. Calif (SFV)
2.9L V6
35x12.50R15
4.0L is a good engine, unless you're trying to tow something you shouldn't be, I'd certainly keep/rebuild it.
Agreed, flush your cooling system out good and then put a new t-stat in (stock 190-195°).
Observer
New member
Alrighty, thanks guys!
On parts searches I get a lot of the standard 195* one, but there is a premium one that I can't seem to find- what does it do that's so special?
Reggie
New member
Mazda
Can the temp sending sensor change the idle and performance of the 4.0?
sheep herder
Well-known member
407
sheep pen
Yes, the temp sensor can. Don't confuse the temp sensor with the temp sender.
