- Nov 7, 2009
- 13
- White Pine, TN
- Ford
- Engine Size
- 302/2.9
I have a 1975 302, I know, it's a low compression 130hp engine, but I'm tight on funds, and this was done in a trade, also the engine I thought had never been rebuilt, has been rebuilt, it's been bored .10 over.
any how my question is, how hard is it to change the rear main seal with out removing the crank???
I know I have to remove the rear main cap, but will the old and new seal slide around the crank to where it needs to be???
I really don't want to pull the crank as I can't afford new bearings, I only pulled the heads because the full gasket kit came with new head gaskets, and I have to spring for new head bolts, or rather studs and nuts.
also on the interweb, I have seen that the inside caps are to be tq to 70 to 80 pounds, and the outers to 35 to 40 pounds, does this sound right???
thank you
Robert
posted with a burnt piece of toast, and toe jam.
thank you
Robert
