exbass94
- Aug 6, 2007
- 39
- Age
- 36
- Guilford, CT
- Ford
- Engine Size
- 4.0 SOHC, 4.0 OHV
So, long story short, I had to replace my rear axle because of bad pinion bearings. My truck originally had a Trac-Lock limited slip, but all the junkyards around here only had regular open diff rear axles. So, I installed an open diff. I don't really like that I just basically downgraded my axle. My original plan was to use this new open diff temporarily, and rebuild my Trac-Lock axle in my spare time and eventually install it back in. But now I'm thinking maybe I can skip rebuilding the old axle and just install some kind of lunchbox locker/limited slip into my new open diff, and have an even better axle than before.
So, what kind of locker or limited slip would you recommend? My requirements are that it must be a "lunchbox" type, something that does not require setting up gears. If I wanted to set up gears, I would just rebuild my old axle like I said.
My truck does not go off-road AT ALL. It is 100% street use but we do get a fair amount of snow in the winter. I'm really curious to see how an open diff does in the snow; hopefully I don't get stuck.
I don't want something too clunky/ratchety around turns. The smoother and less noticeable the better.
I was thinking about the Powertrax No-Slip. Thoughts?
