Lifting 2wd
Jcookie
Vallejo,CA,U.S.A.
Mazda
4 cylinder (for now)
I was talking to a gearhead friend of mine and he said most people avoid liftin the 2wd trucks because it can screw up ur front end like cv joint wear and just odd things like that...any opinions?:icon_confused:
Grey_04
50
pennsylvania
i have 2"coil spacers in the front of mine and the 4x4 spacer blocks between my rear springs and axle. after putting the spacers in the front i had an alignment done and have had no issues in 8,000 miles so far. I'd suggest the 3" front spindle lift, that's my next investment this summer.
3.0ranger1227
11
no worse than lifting a 4wd... actually probably easier on the parts than a 4wd. as long as you don't try to run 37s on your ranger/b-series and you keep up with maintenance you will be fine.
Heim steering FTW :D
Nater
Bamberg, Germany
Mazda
2.3L
Wait....since when did 2wd trucks have CV boots in the front?
Cookie-As long as you have all the required hardware, and keep up on the maintenance, you will have no probs.
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
what the penguin said
daniel3507
74
NE Oklahoma
2.3 EcoBoost
you're buddy may not be as much of a gearhead as he thinks.
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
maybe he hit his head with a gear, and thats why he say hes a gear head? :dunno:
BlackMoses
La Mesa, CA
Actually lifting my front end with a 3" spindle lift was probably the best thing to happen to my front end because it gives you the opportunity to change out the ball joints, tie rods, sway bar links and wheel bearings like I did. But seriously besides maybe needing an alignment to get it just right, lifting your truck with a spindle lift and shackles in the back doesn't hurt anything.
Boggin
48
your buddy is the complete opposite of a gear head, dont ever take any advice from him. if he thinks 2wds have CV joints in the front he is either on some real good dope, or he's very stupid. im guessing the 2nd one
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
thats like the guy who told me body lifts messed up the ball joints...
mp3deviant721
24
Eau Claire, WI
2.3l of fury
With lifted 2wds, you only have to worry about re-gearing one axle instead of two, you only have to worry about the working angles of one drive shaft, you don't have to worry about over stressed CV axles or breaking your transfer case. It's just less parts to worry about. Don't listen to your "gearhead" buddy. He doesn't sound like one at all.
rickf92592
Temecula, CA
6.0L
It will also totally trash your muffler bearings!!
RollinWOT
10
Cochise County
Ford/Kia
3.0L Vulcan/GDI 2.0L
Just be sure to keep your headlight fluid topped off and use rotor wash occasionally and you're good to go. :headbang:
3.0ranger1227
11
and make sure to repack your foglight bearings ever 10K miles.
