Lets Talk about Transmissions (2wd)
stRanger_dAnger
Wilmy, NC
'01
The consensus seems to be that T-5's cant handle the Powa. M5Dr2,, perfect fit? not manual, but the 5R55S is allmost manual.. has anyone tried a paddle-shift ranger? also tell me again why I cant put a T-56 in it. what else has been done? what else works?
Bird76Mojo
1,264
IL
T5's can't handle the power? That's news to me and my V8 Ranger, and millions of Foxbody's....
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I dunno what your building but if a T5 can't handle "the powa" a 5r55S has no hope...
stRanger_dAnger
Wilmy, NC
'01
I used the 4R70W that came behind the '99 Explorer engine.
Does the 4spd doit for you? I want 6 but I guess with the right ratio 4 would do the trick.
Heard.
I take it you both used the T5, I meant no offense, I just want boost.. if you're happy then Im happy for you. I thought the extra weight wore it out a bit but if it goes, it goes.
What do we know about other options?
19Walt93
4,453
Canaan,NH
351
3"
235/55R16
My 13 second Mustang II has a transplanted T5 that has survived 20+ years of drag racing. I've seen a bunch of relatively stock fox bodies with blowers bolted on running 11's until the head gaskets went to lunch. If you have to buy a transmission I'd look at some of the Tremec stuff because it has a higher torque rating. A 4R70W has a torque convertor as well as 4 speeds and is a good transmission if you don't have to have a clutch pedal
stRanger_dAnger
Wilmy, NC
'01
So is this all to say the T5 is the best match? is the trans crossmember in position? no word on the M50Dr2.. is there a reason?
19Walt93
4,453
Canaan,NH
351
3"
235/55R16
I suspect you'll have to move the crossmember or fabricate one. There are a bunch of T5's to be had used so the price should be reasonable. The M5OD was used in 2wd F150's which are almost unheard of in NH, plus, I personally don't like them
