legitimate question...please try and help me out.
maroon ranger
East Helena, Montana
1994 4.0L proje
Okay everyone. Its finally time to through in my d44 solid axle and 9 inch!!!!! I've searched for hours and hours in the past few months and have seen mixed answers. So let me just ask this.
I'm am going to do 64 inch stock Chevy leaves in the back with belltech 6400 shackles and am not huge about using the stock factory blocks. So what gain in height would I get over stock height without using the blocks. That is basically how I am going to determine my front springs. So with that said what are your recommendations and advice.
Is my current plan of using 3.5" early bronco lift springs with 4 degree bushings and stock 64" Chevy leafs with 6400 shackles and no blocks going to work out pretty good?
Keep in mind I'm also going to be using 35 inch tires.
I appreciate any advice in advance.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I haven't done a SAS on a 3rd gen yet but I'm using the eb 3.5" lift springs with f150 coil buckets and Chevy leafs with 2" add a leafs on my 1st gen SAS. I used the stock bushings and I clear 35's but I had previously trimmed my fenders to clear 33's back when it was semi stock height.
If you have a torch and a welder I suggest trimming a set of F150 buckets, drilling 3 holes 1" apart up both sides then building brackets of 1/4" plate steel to match but with 2-3 extra holes and welding the brackets to your frame so you can adjust your buckets up or down for the height you want to match your rear end.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
With stock leafs, a stock block and extended shackles my 91 sat level with a 5" front lift.
maroon ranger
1994 4.0L proje
Sweet sounds like I'm doing pretty good on my studies!! Hahaha thanks guys for the help!!!! I will have get my swap done soon and let you guys know how it all turned out!!!!
