Learn from my mistake
Junglejoe
66
Columbia Missouri
6.0
Can't use an explorer oil filter relocater?
svtcards
137
Lyman maine
302
3'' front 4''back
That sucks!I have trans dapt at the moment but I replaced all hardware to -an fittings and braided hose because I read somewhere that the factory fittings and or hose leaked.have u tried a different oil filter brand?I had that problem on my mustang.i used fram filter on it and I couldn't get it to stop leaking around filter seal as well.i switched it to a motorcraft problem solved.it might not of been housings just how filter was made itself.i think trans dapt recommends ph8a if I recall right.i might go to motorcraft right away since your having issues.good stuff.
19Walt93
4,411
Canaan,NH
351
3"
235/55R16
I saw a relocation kit with the adapter bolted to the engine in the center instead of spun on like an oil filter but I don't remember the brand. The one I bought screws on and it's going to make it tough when I take the engine back out.
svtcards
137
Lyman maine
302
3'' front 4''back
Which one do u have?u put relocators after engine was in not before?
Daniel Black
44
Leicester, NC
302
205/60R15 & 225/60R15
I'll have to look into the Explorer oil filter mount. I don't know what it looks like. I always use a Motorcraft filter on everything. This is the second 302 I've had in this truck and I always put the block mount on before the motor goes in just to make it easier but it should have room to put it on afterwards.
svtcards
137
Lyman maine
302
3'' front 4''back
That's wired!maybe try a different brand filter before u buy another whole new setup.cheaper that way.
svtcards
137
Lyman maine
302
3'' front 4''back
Does that fit in the frame rails of a ranger?
Daniel Black
44
Leicester, NC
302
That Explorer mount looks huge. I don't think that would fit.
svtcards
137
Lyman maine
302
3'' front 4''back
Which mount did u end up using?
Daniel Black
44
Leicester, NC
302
I use the Trans-Dapt block mounted part that came with their motor mount kit. The PermaCool filter mount is still leaking. Not enough to be super concerned but enough to make a mess.
svtcards
137
Lyman maine
302
3'' front 4''back
Do have the part # for that kit by any chance.i got wrong kit so need the 90 degree mount that u have on your engine
Daniel Black
44
Leicester, NC
302
svtcards
137
Lyman maine
302
3'' front 4''back
You just plugged up the other 2 ports and it worked pretty good?
Daniel Black
44
Leicester, NC
302
Yeah, it came with plugs for the two ports I didn't use. So far, knock on wood, I haven't had any issues with the block part leaking. You just have to get lucky where it tightens up at. I guess it could tighten where you couldn't get a line on any of the ports.
Kirby N.
March Truck of The Month
