Leaking after rad change
JohnG
39
Knoxville TN
Ford Ranger STX
235/75R15
We need to stop messing with the framework that the founding fathers created.
dumb question for the day...
How do I stop the leaking from the transmission line going into the radiator? I have gradually tightened it fittings down but afraid I’m going to crack the tank or strip threads if I tighten it much more. Should the fittings have some sort of sealing tape or other stuff on the threads?
dvdswan
2,896
Seattle, WA
Ranger XLT 2WD
It wouldn't hurt to use tephlon tape. Just be sure not to cover the hole of the fitting.
8,292
+1 ^^^
Its a flare nut fitting so unscrew it and pull nut back a bit and wipe down the flare so the is no debris on it or the nut
Yes you can use sealing or teflon tape on the threads, but the seal should be at the flare where it meets the connector inside and the nut pushing down on the back side of flare
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Unfortunatley, I have had new flare fittings that just never worked no matter what I did. Rare though, usually its my error.
dvdswan
2,896
Seattle, WA
Ranger XLT 2WD
There are 2 angles of flare fittings. 45* SAE and 37* AN fitting. So it is possible you don't have the proper contact needed.
JohnG
39
Knoxville TN
Ford Ranger STX
235/75R15
I’m embarrassed to say but it is fixed. I believe that I simply hadn’t tightened all the fittings enough.
Thanks yet again for all the knowledge shared!
wildbill23c
570
Southwestern Idaho
215/70-R14
wait I don't think there should be any coolant coming out of those fittings in the first place. That transmission cooler is separate from the coolant passages in the radiator. If you are getting engine coolant out of those fittings the internal transmission cooler in the radiator is damaged...you'll induce coolant into your transmission and destroy the transmission.
JohnG
39
Knoxville TN
Ford Ranger STX
235/75R15
Luckily mine was leaking only transmission fluid. But good to know for the future reference.
thanks wildbill
Kirby N.
March Truck of The Month
