jrvmosjr
- Sep 23, 2021
- 0
- Houston, TX
- Ford Ranger Edg
Hello All,
I am new here, hoping to find some answers.
I have a 2003 Ford Ranger Edge 3.0 2wd auto.
Noticed some leaks from under the engine.
I could replace all the gaskets myself but just haven't had time so I had a shop by me do it.
Valve cover gaskets, oil pan gasket, front crank seal, and rear main seal. Heck they even did the trans tail shaft and rear end cover and pinion gear.
Everything is holdin up except for the rear/oil pan. It is pissing like a scared pup, Rear main seal replaced twice, new oil pan/bolts and 2nd gasket installed.
Still leaks!!! Comes straight down the rear of the oil pan it seems. Oil sending and cam sensors on rear of block checked and replaced. Any ideas!!?? Thanks in advance!
