Leaf springs AND coilovers in the rear?
JediJesus
Illinois
I just posted about upgrading the engine in my 2wd 1992 Ranger, 2.3l to make it faster. (here's the thread) But along with making it faster, I want to make the truck a little stiffer to handle corners better, and with less body roll. I've looked into a 4 link rear coilover conversion kit, and it's about $800 - $900, which I don't have, nor am I willing to spend that right now.
So my question is would it be ok to keep the leaf spring and replace the rear shocks with coilovers, along with coilovers in the front? Or is that not possible? Replacing the rear shocks with coilovers would mean the rear would have leaf springs AND coilovers, so would that work? Any advice helps, and if you have any further questions, please ask and I'll try my best to answer!
MikeG
752
central Texas
B4000
2"
235/75r15
Explorer springs will be the cheapest way to make the rear suspension quite a bit stiffer... but be careful what you ask for. Mine rides like a dump truck, empty (needed the capacity at that time so no big deal).
Rear shock mounts aren't all that substantial on a Ranger, I wouldn't get carried away loading them down.
Stiffer sway bars probably worth looking into if you want flatter cornering, but not the dump-truck ride. Lower profile tires too, if you don't go off road.
A few thoughts.
17,822
SW Iowa
Sway bars are good, optional both front and rear so you may not even have any now.
Mine had a front one from the factory, adding the smallest OEM (5/8" third gen) rear sway bar made A TON of difference and that was with a lifted 4wd. The stock sway bar for a first or second gen is 3/4", the mythical 2wd BII had a 1" sway bar. And there are aftermarkets out there since the same sway bar that fits a 83 will fit an '11 (aside from the 31 spline 8.8)
If you swap in an Explorer rear axle you can adapt F-150 axle clamps to fit or the best (IMO) is to make the Explorer sway bar fit, basically just drill two holes in the frame for the links.
I am not totally sure how the 2wd's are set up. The stock first gen sway bar mounts inside the radius arms, later trucks have them mounted ahead of the axle. If you REALLY wanted to get serious you could run both, they wouldn't interfere with each other. I am not a suspension expert, have not tried it and I do not know if any weird idiosyncrasies would arise from doing so.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Adding coil overs to the rear will just make it ride like a brick...
Get a rear sway bar and good shocks.
On the front, Bilstein shocks and poly bushings on the sway bar will help.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
ive got coils & leafs both on the back. no sway bar. Did it mostly for load capacity since my stock rear suspension was a single fiberglass leaf. The coil helpers I put on are a 2,500# rated spring. Yes it rides a little stiffer but not bad with a load.
View attachment 57887View attachment 57888
I'm so confused by that...
franklin2
1,758
Virginia
What amazed me is when I replaced the stock rubber body bushings with the plastic poly bushings. Just doing that really tightened it up in the corners. The body has a lot of stiffness to it, the frame does not. Tie them together better and it really helps.
JediJesus
Illinois
Actually that's a good point, especially considering the fact that the body mount under my radiator on the passenger side is half missing 😂😂
JediJesus
Illinois
Oh ok, that makes sense, and I'll look into a rear sway bar, Bilstein shocks and poly bushings. Thank you!
JediJesus
Illinois
Others have also mentioned a rear sway bar, I'll have to look into it! Thank you!
JediJesus
Illinois
A few thoughts.
I don't go off road a whole lot, but the roads around here are REALLY bad. We have a lot of dirt/sand/gravel roads, and some of the potholes hurt even with stock wheels and tires. So I'll probably keep the stock tire profile. Also would getting a bit wider tires be an alternative to lower profile? Or would that be worse than stock?
