MrEvilPirate
- Apr 2, 2017
- Reaction score
- 0
- Location
- Central CT
- Make / Model
- Ford
- Engine Size
- 4.0
- Manual
- My credo
- MAGA!!!
I looked around the forum and watched a bunch of youtube videos, but the videos always cut and resume after the knuckle is removed.
I'm trying to do ball joints on a 2002 Ranger 4x4 w/torsion suspension.
Upper control arm is disconnected from the knuckle. Caliper is off. Axle nut is off and axle is moving in and out, so far so good. Castle nut on lower ball joint removed then screwed back on to catch the knuckle when it releases (yeah right).
So it looks like the knuckle is just floating there. I put some 2x4s on the top of the knuckle and beat on it with a mini sledge. Eventually I got tired of splitting wood. Hit it with PB Blaster and a map torch no luck. The side I'm working on is sitting on a jack stand under the lower control arm right next to the lower ball joint but not blocking anything.
What am I missing? I looked at it one last time before throwing in the towel. looks like removing the dust shield opens up some space to try to use one of those ball joint forks to separate the knuckle from the lower ball joint. None of the videos or procedures say you need to do this, it is always "then remove the knuckle" help please!!
