AvlAndrew
- Sep 4, 2021
- 11
- Asheville,NC
- Ford Bronco ii
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
I just repaired a 90 B2 engine, that had a bent intake valve due to a bad fuel injector
so re-installed the engine, its running smoothly, but there is a knock at idle from what seems like the bottom end where the oil pump is located. this knock goes away at 2k rpm. I am inclined to replace the oil pump.. any suggestions appreciated.
