It looks like I have a stock ranger frame measurement (from a helpful member) of 28 9/16" at the coil buckets. Compared to 33 7/16" on the bronco, it is 4 7/8" total difference- So that is 2 7/16" per side.
I cut all the mounts off. First I measured how far each bushing was from the outer "c".
Then I put the lower outer "c's" (where the lower ball joint mounts up) at 0 degrees. Then I measured each bushing's angle and marked it down.
Then I wrote everything down carefully on the trusty garage dry erase board and marked each bushing with a "top" which side it goes on and if it is front or back.
Then I cut each weld with a grinder and cut off wheel and drove them off with a big hammer and a piece of solid stock.
I also welded the tubes to the center section. I had some moist spots on my other housing around where the tubes go in from time to time, making me think welding the tubes even on a 1/2" tubes housing like this was even a good idea. After two passes last night, it was still cracking due to different cooling speeds of the cast center and tubes. In the past 2 passes got everything very warm and I let it cool slow in the open air and got away with it. This time I wasn't so lucky- maybe it's the thick tubes? Anyway, applied some pre and post heat with the trusted oxy acetylene torch and did another pass and she is good to go. Welded with my 220 buzz box turned up hot and 7018 rod.
Tada! All ready to clean up and tack the mounts back on!
One thing I am thinking over is that on my Navajo I had a single sheer lower trac at mount utilizing the stock mount and a 3/4" heim. If you look closely you can see the mount here:
Hiems suck for daily driving in the weather, so I would like to use a double sheer lower mount, with a poly upper and a "super joint" type of joint- spherical joint with Teflon inserts on the other end. We learned this lesson on my buddies bronco. However, we left the stock mount and welded to it. This cost an inch or so of potential trac bar length. You can see it here:
I am considering cutting off most of the stock mount and welding the double sheer to it. It will have to be kept low profile, however to clear the spring cups.
