Kicking my arse.
Therigwelder
Mississippi
Ford ranger
i have a93 ranger I cannot figure out. It all started with a 224 code that was a failing ICM.one night I parked the truck and it was running however the next morning the truck wouldn't start. I replaced the ICM, CPS and the timing belt (maintenance).using a multi meter I confirmed power to the ICM, CPS. I checked the shared ground wire to ensure everything was grounded properly. While hand turning the crankshaft I checked the signal voltages from the CPS to the ICM, while hand cranking the engine. Output voltage was at 9v for both the CID and CPS signals. I have a weak orange spark on the #2 exhaust Spark plug. I have no spark on the intake side plugs. If I am not mistaken that would be correct,the intake side doesn’t fire till the truck starts? I still have a no run condition and it’s got me at wits end.what am I missing? Maybe the ICM isn’t grounding properly even though I got 12 v when I checked it with a meter from B+ to orange/red ground ICM wire?
8,369
1989 to 1994 2.3l Rangers use an ICM(ignition control module) for spark
There will be NO SPARK on the intake side coil while starter motor is active, that is normal, it starts working above 400RPM, there is a "Dual Plug inhibitor wire" on the ICM, pin 6
By "CPS" do you mean Crank Sensor, usually abbreviated CKP sensor, CPS is usually used for Cam Sensor
Crank sensor on 1993 is hall effect type, you should see 0v and then 12v, off and on, as you rotate engine manually, you really need a scope to see the Pulse its sending out verses voltage
Any time you have a crank but no start on any engine, spray some fuel into the engine, gasoline or ether, and try to start it, called 50/50 test
If it starts and dies then you have a fuel delivery problem
If it doesn't start/fire then you have a spark problem
50/50 instant results
These use a Waste Spark system so "spark testers" don't work very well since 2 spark plugs are hooked up in series, its not like a distributor spark system
Yes, the ICMs on these engines were troublesome, most auto parts stores can test them
1995 and up 2.3ls have ICM in the computer so all spark plugs work while starter is active
Therigwelder
Mississippi
Ford ranger
Thanks, I’ve confirmed it’s getting fuel. I changed The timing belt since I had to take the front cover off for the CPS.brought it to TDC of compression stroke, lined the crank with the bottom housing notch, lined the cam diamond to the slots on the back cover and turned the diamond on the oil pump to centerline of the cam. Not that it’s necessary to align the pump.confident timing is right.engine cranks as if timing is right.doesn't spin free or like it’s retarded. I believe I have an electrical issue causing the problem. What’s the possibility of during the original ICM failure it also burnt out the coils as well? My ICM and CPS tested bad at the same time.ECM issue? I need this truck but don’t want to throw parts at it and waste money.
8,369
Diamond?............................Cam gear uses Triangle at 4:00
AUX(oil pump) gear use diamond at 12:00
These gears are the same size and interchangeable, so most will have BOTH timing marks, a Diamond and a Triangle
A rubbed "half" Diamond can look like a Triangle
Just do a 50/50 test, its free and very very easy to do
