Well I have the feeling that whenever I do something, and I do it, it's just that more special. Having the feeling that... hey, I BUILT THAT BOX! So i think im going to build it myself. Any potential problems or tips and tricks to tell me about before I start?
I will go with the 3/4 board cause ya gotta do it right the first time. I will also use fatmat on the inside of the box. And I already was going to glue it and screw it. Will any type of carpet do? And all i would need to do is staple it on the box, Right? Also, if I use fatmat on the inside, can I use 5/8" and be just as good as 3/4"?
I am new to carpeting though. Is there a site i could go to (or a thread already posted) That gives a good walk thruogh on how to carpet a box?
On a seperate note, I have been doing autoCAD Designs for a while now and have not been able to make a box that works with the kicker 12" CVT.and fits in my standard cab. Can anyone help me out here? I dont think i can go any higher than (correct me if i'm wrong) 13" tall because the back of the cab comes out a bit at 13". It would be preferable that it be angled too because im 6'2" and the seat goes all the way back, and I dont want the passenger seat sticking way out.
And if this helps out anybody, the specs for the 12" Kicker CVT is as follows;
Mounting Depth (IN.,CM) 4-5/16, 10.9
Mounting Cutout (IN.,CM) 10-15/16, 27.8
Min Rec Sealed Box Volume (CU. FT., Liters) 1.0, 28.3
Max Rec Sealed Box Volume (CU. FT., Liters) 4.6, 130
Min Rec Vented Box Volume (CU. Ft., Liters) 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters) 2.25, 63.7
Any help would be awesome and thank you guys so much for all the posts.
EDIT: I just looked up the price for a 12"Kicker CVR and its 15 dollars less than the kicker CVT. Should I use the CVR instead of the CVT?
