Key on voltage
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Good place to steal key on 12V in the cab? 88 Bronco II
Thanks in advanced!
Jazzer
457
Indianapolis
If your cigarette lighter is always on, you can get it there, should be on a 20A fuse.
Jazzer
457
Indianapolis
Misread your post as always on, sorry.
Radio should be key on.
rumblecloud
1,119
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
I've heard the battery is a good spot, but you need longer leads for your multimeter.....😬
EDIT
I mis-understood. I thought you were looking to test your battery voltage with the KO
My attempt at a funny was a total fail.
ericbphoto
Overlander in development
16,551
Wellford, SC
3.0L
6"
First place I like to look is unused spaces in the fuse block. Sometimes you find one for an uninstalled accessory that actually has the contacts in the fuse block ready to re-appropriate for your purpose.
8,369
Fuse box has several fuses that are key on, RUN only or RUN and ACC(like the radio)
Get out the 12v test light(volt meter) and test which fuse have 12v in the manner you want
Then pull out that fuse and test which terminal has the 12v with key on
Then use an "add-a-fuse", google it, to get your power
Add a fuse plugs into your fuse box and has TWO fuse holders, one for current fuse and one for the new fuse with new wire
If you just splice in to say the Radio 12v wire then its more than likely when you are using the "new device" it will blow the radio fuse over time
So no "new device" and no radio, lol
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
A fuse splice was my next idea if I couldn’t find any blank ports. Wish it had somewhere just hanging like a super duty with Aux switches.. I’ll be probe out the panel to verify. I have plenty of mini splices guess I’ll be ordering some standard ones.. 😂
8,369
You can buy a $10 12volt relay w/base and splice it into any 12v key on wire, relays only require 0.5amp to activate so won't cause an issue with the circuit
Then use the cigar lighter's full time, 20amp, circuit to power the "new device" via the relay
No members online now.
