- Sep 21, 2007
- 656
- Wa, Bremerton 98310
- Ford
- Engine Size
- 87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
- 2WD / 4WD
- 4WD
- Total Lift
- Ranger 5" (2" suspension), BII 4" suspension
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 33"/4:10LS, BII 29"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
JMF,
One thing is for certain, if your not running as cool as usual, something is probably up.
There have been a few really good suggestions to correct your temps:
-an engine oil cooler is a very economic, sound method to reduce both engine and under hood temps
-deleting the crankshaft fan/clutch for an electric setup will free up some power stolen to spin that HEAVY crank clutch/fan setup. I have found, even while in Arizona/S. California in the heat of Summer that I didn't need any fan unless at a stop light or driving under 35 mpg (the only times my electric fan ever needed to be on). Additionally, of all my efforts to improve fuel economy, no single other change has caused a greater improvement in fuel economy than taking off that crankshaft driven fan/clutch.
I have a truobleshooting suggestion which usually shows me what's really wrong with cooling issues and it's almost free. Install a new radiator cap, remove the thermostat and carry 2 jugs of water until you know what's up. If there is a problem with your cooling system, without a Tstat, it should reveal itself inside 2 weeks normal driving.
The problems this method has revieled to me are:
-leaking heater core
-leaking radiator cap
-bad or slow opening Tstat
-dead water pump
-leaking water hose
-leaking radiator
-compromised engine head gasket
One additional benifit to briefly operating your vehicle this way, in that environment is that you will see what temp it runs at with FULL COOLING POTENTIAL, at all times. It will run a little cool or at least it should. If you happen to be losing coolant slowly, this will speed it up so that you can see.
-dead water pump
-leaking water hose
-leaking radiator
