chessman21
- Jan 7, 2016
- 0
- 1969 f-600hd
- 1991 ranger 4.0
should i remove thermostat before adding this permanent metallic K&w block/head seal stuff? Instruction dont say to but i dont know what the thermostats working condition is, it is new but after running almost hot plus now temp fluctuates from almost warm to almost hot back and and forth almost continuously now i dont whats going on under there.
I dont think system is building pressure either. Can the lower intake manifold gasket be the source of the leak vs the head/gaskets? If so can that be fixed without taking the heads off?
Be beter to find used engine?
Should i put a 302 in it... Whats the best years that fits?
Prolly doesn't work with the a4ld tranny id assume?
