Just curious
superj
3,588
corpus christi, texas
ranger edge
182 ci of tire shredding power
2, so far
235s
drives a stick shift ranger
man, you guys make me want to cut my front stops and lower the torsion bars down to where they were when i got the truck (sitting on the stops and rode like a wagon but looked cool).
i just need to measure the u-bolts so i can remove the stock 2" lift block my truck has.
lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
7,669
Butler, PA, USSA
5.0l
4”
I unbolted my front stops, you have to have the suspension unloaded (jack up under the engine crossmember) and I believe it’s a 10mm 1/4” drive deep socket to slide up in the stop to get to the bolt.
superj
3,588
ranger edge
2, so far
235s
and getting off my butt to measure the u-bolts since i have the 8.8. everything online shows me u-bolts for the 7. i would think the axle tubes are larger on the 8.8 so i have not gotten shorter bolts and taken out that dang spacer.
even if i just took the spacer out and left hte front sitting how it is now, it would look cool. when the other stepside ranger at work and i end up next to each other in the parking lot, my back end of hte bed is a few inches taller then his. he is a 2wd xl so it really shows the differences the edge has over the other 2wd models
scotts90ranger
5,588
Dayton Oregon
2.3 Turbo
Other than the FX4 level 2 the U bolts are the same on either axle, the axle tubes neck down between the spring perches and diff on the 28 spline 8.8 where the 7.5 are straight...
bobbywalter
TRS Technical Staff
Ugly Truck of Month
6,048
woodhaven mi
FORD mostly
BIGGER
sawzall?
back in the 90s there was a badass lowered ttb in the downriver that did pretty good.
you can block up your upper control arm to go lower. not too hard to do.
NakedDucks
129
B’ham AL
God’s plan, not mine.
@JoshT
I was wondering as I have the 03 body and frame, so if I’m swapping out of an explorer, I’d be using all of that wiring and drivetrain.
JoshT
3,105
Macon/Fort Valley, GA
IIRC that 03 is a 2wd. Is it torsion bar or coil spring? If it's coil spring you can't install the front 4x4 components.
I seem to recall that even the torsion bar 2wd is missing some bracketry for mounting the front differential, though those could probably be sourced from the same explorer and welded in.
For a torsion bar truck, you've pretty much seen the limit of stock components with mine and lil_Blue_Ford's trucks. To go lower would require custom components, namely control arms, that we're having trouble sourcing right now.
To go lower, I see Bobby's sugestion of "block up your upper control arm" and I'm honestly not certain what he is talking about there. I've seen suggestions to raise the mounting points for the upper arms and raised mounts are available, but that would require cutting and welding the to the frame that I'm not willing to do. Even if I were willing, I do not think it would be a viable option with the torque monster style headers. Best option would be extended control arm(s) with corrected joint angle, but can't find a source at current.
lil_Blue_Ford
Cut & Weld
7,669
Butler, PA, USSA
5.0l
4”
I’d also say that to go much lower than my truck or @JoshT , you may start to run into other issues. Lower ball joints (not as big of a problem as the uppers since it’s stamped steel so easy to do a cut and turn), but there’s also the bracket for the bump stops that isn’t real far away. Obviously shocks. Possibly start to push the angle for the CV shafts. Possibly start to run into issues with the steering rack where you may have to flip the tie rod ends or something.
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
