OskarBlue
- Jan 5, 2018
- 1
- Colorado
- Ford
- Engine Size
- 3.0 V6
So I just changed my valve cover gaskets, upper intake manifold gasket, and spark plug wires. When I did a test drive, I found my engine was running rough, and the truck really doesn't want to accelerate. Upon acceleration I heard knocking coming from the engine. Help me figure out what I might have done wrong?
No CEL so I can't check for codes.
Here's everything I did:
- removed/disconnected everything in the way in order to remove upper intake manifold and valve covers (vacuum hoses, throttle body, ignition coil, etc.)
- replaced upper intake manifold gasket
- replaced valve cover gaskets (this was the main reason for all the work)
- replaced spark plug wires (plugs were changed ~2k ago)
- drained/refilled cooling system
- replaced fuel filter
- changed oil/oil filter
I'm certain the plug wires are all going to the correct cylinders and are seated correctly.
I'm reasonably certain I did all the gaskets correctly, but could I have done something wrong with them?
My suspicion is vacuum leak, but this is outside my realm of experience so far. Could I have not reconnected a hose properly, or disconnected something unknowingly? I'm about to go double check them all and spray them all with carb cleaner and see if I turn up and leads.
I did find a degraded vacuum hose (dry rotted) I want to replace, but haven't done it yet. It worked fine before. Could handling it have caused it to fail? Would that be causing this large of an issue?
Could I have messed up my MAF sensor somehow?
Any other ideas for things I could have done wrong that would be causing the problems I'm experiencing? Would appreciate any input!
