lowspeedpursuit
- May 6, 2022
- 107
- DE
- B2300
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 4WD
I don't know a ton about electronic logic, especially AC and converting between different types of signal. I wonder why the wiring diagrams break VSS ground out separately, then? I assumed they want a more direct path to avoid the potential for too much resistance along the common ground, but it could save trouble extending that PK/O wire if it isn't really necessary.
I think the VSS probably checks out at this point, although I still wish there was a way to test its output directly. 8000 p/mi should also be 8000 p/min @ 60mph, which gives 35/60*8000 = 4667 p/min @ 35mph. So, I feel like you should be able to divide that by 60 and measure 78Hz with a capable multimeter, but mine shows 1kHz, so I must be misunderstanding something.
Various parts will be here Wednesday. I grabbed a '94 Mustang module for $20, but I won't know if it's actually compatible inside until it gets here. Affordable green-box modules are basically hen's teeth around here at this point.
A way to test the modules would also be nice, but while I understand what they do, how exactly they work depends on the chip inside, which is kind of a black hole of information.
