Joined to ask dumb questions
ReneGoFast
Gr, Mi
Hello! I've been lurkin' around for quite sometime now. having read and used quite a lot of info off TRS to keep my Ranger running. I bought it with 149K on the odometer, it now reads 217K I'm guesssing it probably closer to 300K 'cause the odomerter gets stuck on .7 and just sits there for days, Like I drove from Grand Rapids, MI to Cleveland, OH and back...and only logged 17miles!! I' ve gone thru 2 sets of 14" tires and am wearing thin on a set of 15"s I got off a '98. I also have replaced front disc pads twice and rotors once. along with most of the brake lines. I know it's time to do the rear drums and shoes, as they grind when turning corners. I'm sure the shoes are worn well into the drums and expect to wear myself out with a BFH breakin the rust seal and or worn lip on the drum(s) I want to have new drums, shoes and hardware all ready before I start. SO, my dumb question is where or how do I measure the drum to tell whether I have 9" or 10" Drums?? Is i the ID or OD? Thanks for providing all the information you do on this forum, I'm glad to now be a member!!
Rock Auto 5% Discount Code: 81874766E40C6A 5th, 2022
Mac
181
C. Wisconsin
2000
199
Welcome! Easiest way to tell the size is that the 10" are smooth on the outside while the 9" have flutes on the outside. Size is also cast into the rim O.D. as is the allowable size for turning.
Dave
Insanejughead
29
Missouri
'94, '86
2.3T
I looked at this post to see some dumb answers to dumb questions...
However, all I found is a good question with two good answers.
Why am I disappointed?...
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
7,837
Jackson, NJ
'79,'94,'02,'20
All Fords
Insanejughead
29
Missouri
'94, '86
2.3T
Hahahaha! I didn't expect THAT!
I would say ReneGoFast got more then he/she bargained for in this post.
3,568
Because this is TRS, and it just isn't TRS if we don't go blow up some poor unsuspecting guy (or gal)'s thread.
88_Eddie
156
Raleigh, NC
2.9L, 4.0L
i've got a set of 8.8 drums and shoes that have never been run that i'll sell you cheap if you want them. i got a disc 8.8 so i never got a chance to use them.
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
7,837
Jackson, NJ
'79,'94,'02,'20
All Fords
In our defense... We usually answer the original question somewhere in the incoherent ramblings.
3,568
Insanejughead
29
Missouri
'94, '86
2.3T
OH GOD! NOT THE CLOWN CLOuD!!!
IT'S SO HAPPY... :shok:
85broncduece
so cal
171ci v6
just thought id chime in here. but if the brakes are grinding in turns you may also have some bearing issues.just a thought.
kryptonitecb
17
Fort Worth, TX
....where was the question in the op rambling?
Sent from the road while ignoring traffic
armadillon
10
Austin, TX
Today has been an awful day for punctuation. Definitely need indentations.
EDIT: I typed indentation and I was like "Oh my god I spelled it wrong it's indention!" After double checking both spellings are correct. What a strange day...
