Jeep springs in 95 ranger
MRMDX
Auburn, Washington
I have a 95 ranger and have put 19in jeep coil springs into my stock front end, they bow out heavily but ive been told its done, what am i missing?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
you need custom buckets or seats.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
you can get extended studs or just use a bolt/washers combined with 2 inch pipe flanges and nipples cut at a angle to correct the bow and working arc.
that with air bags gives you some serious range of tuning and suspension travel at low speed.
MRMDX
Auburn, Washington
thank you for the quick replies, and that will fix it though i do not have any extended radius arms or anything? i saw the piping fix in the tech articles but he had mentioned extended radius arms
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
19 in is too tall for stock brackets and arms.
what is the ppi?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
depends on ppi. 16 inch installed is about max iirc...memory is not what it used to be
generally 1 in spacer and hd plow coils get ya 2.5-3 in
what is current measured spring height with stock springs?
the 19 in coil can work if your under 17 measured installed.
use a ratchet strap or rope and bind the coils straight...under 16 inch should be align-able with 3 degree bushings.
MRMDX
Auburn, Washington
ppi is 240 or 250 i believe and i am not sure about stock spring height, what do you mean use a ratchet strap or rope to keep it straight? and good to know about the bushing
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i assume from this the coils installed are bowing out ....if you hook a strap to it and pull it in so it is "straight-ish" and get the overall installed measurement you can make a determination whether or not it is worth canting the seats with the flange adapters......
240 is pretty good.
MRMDX
Auburn, Washington
240 is pretty good.
ok thank you so much ill do that tomorrow and will let you know.
