Is this fuel injector ok to use?
ssmason85
Seattle, WA
4.0L V6 OHV
Live simply so that others may simply live.
Hi all, I cracked this little plastic piece off 2 of my 6 injectors while removing them from the manifold. Can they still be used if I slap new O-rings on them, or should I replace?
Thanks!
Where did they end up? Unless they broke you should be able to reinstall that piece.
fastpakr
2,832
Roanoke, VA
You can also buy a set of o-rings, filters, and those caps on eBay for all your injectors. I think a set was $10-15?
