Mrtin
- Oct 23, 2009
- Reaction score
- 0
- Location
- Austin, TX
- Make / Model
- Ford
- Engine Size
- 2.3L
- Manual
Just replaced my transmission, a 2wd R1. Also replaced clutch, flywheel, master and slave.
I'm having trouble shifting, particularly into second and third. The pedal is firm all the way to the ground and I have no problem shifting into first or reverse, nor into fourth or fifth.
It does not happen all the time, not nearly, but when it wont go into gear holding light pressure against the shifter DOES NOT let it drop in after a second. It will stay out of gear all day. There is no grinding or noise, it is just like the shifter is hitting a wall. I never jam it into place. Pumping the clutch pedal hard a few time between shifts seems to help quite a lot. This is the reason I assume it is a pressure issue.
I've read a great deal on here about bleeding this system. It does seem like it can take some time. I'm wondering if the problem I describe does in fact sound like an issue of air in the system to all of you. As I put in another old transmission which I never felt in operation, it is possible I've just inherited some problems. But again, pumping the pedal does help.
I will continue trying to bleed it if this sounds like a worthwhile thing to do. No leaks that I can see, and the fluid level is remaining constant.
Thanks in advance for any input.
