Is there a bolt on steering fix, or fixes, for my TTB?
85_Ranger4x4
17,804
SW Iowa
I was totally ready to just bite the bullet and replace the steering box. It got downright sketchy on the highway.
Turns out the intermediate shaft between the steering column and steering box is set up to telescope slightly. There is supposed to be a plastic sleeve in between the two halves... mine had deteriorated due to age and had left the building.
I snagged a new to me shaft from the JY with an intact bushing and good rag joint and it steers great.
rumblecloud
1,120
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Ummm...what's a rag joint?
Image anyone?
Thanks.
r
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
rumblecloud
1,120
48022
Ranger Splash
Stock
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I already did the rag joint, didn't know u joint was an option. Will upgrade.
Local reman box sounds like the ticket.
IDK to me theoretically, Rack and pinion seems not only superior, but a much simpler and easier design. I wish they had come up with it sooner lol.
85_Ranger4x4
17,804
SW Iowa
Not really x2 and not compatable with TIB/TTB.
Ranger used the same steering box as bigger F-series (as in F-150 and bigger). That is a ton of beef for a little truck.
As smaller vehicles go to rack and pinion for lighter weight and sportier driving dynamics the big trucks (now only super duty) are still using the same style box because they are stronger and hold up better.
AndyB.
142
Cincinnati, OH
There are a dozen parts besides the gear box that can make for loose steering. There’s also an adjustment detailed in the service manual to tighten up the box.
With in-spec parts and correctly adjusted, you should be able to hold 70 mph with one hand.
No members online now.
