Lil'Red1997
- Dec 6, 2019
- Reaction score
- 2
- Location
- Kansas City
- Make / Model
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- Manual
- 2WD / 4WD
- 2WD
I have a 97 2.3 manual 2wd. It does not have any codes and runs fairly well. I've averaged about 20mpg in the 3000 miles I've had the truck which I understand is fairly low. I've read rangers aren't quick but this think makes my prius seem zippy. I can live with poor mileage and acceleration as it's just a play thing but I don't wanna get left stranded.
It starts and runs just fine when it's cold aka my commute to and from work. Sometimes, but not all the time, the truck will refuse to run after a brief stop. It will start, run for 2-3 seconds and die. Cycle key on and off run 2-3 seconds and die. For instance I've shut it off to run into a coffee shop to pick up my order from the to-go shelf and the truck will not run. To be clear, it will have been sitting for less than two minutes and not start. After a few cycles of key on-off stumble/die it will start and run no problem. I have also had this issue after killing it at a stop sign, stopping to get gas, and even shopping for about 20 minutes (the wife was with me and it started first try after she got out of the truck to listen for the fuel pump).
I have jumpered out the inertia switch and changed the fuel filter. Holding the gas pedal to the floor while cranking doesn't seem to make a difference (won't fire at all) and neither does pumping the pedal before/during/after cranking. When it is running for those few seconds pumping the throttle kills it immediately. Cycling the key on and off to prime the fuel pump doesn't seem to make a difference either. I have replaced the relay with a "known good" relay a friend gave me from a chevy that was in a junkyard. It has not died while running.
Any ideas?
Any ideas?
