intake manifold confuses me
Zapper
Yes i can afford this without "daddies money"
45
Buhl,ID
1986ish
ford ranger
2.294e+6 cubic millimeters
shot bushings?
235/75/r15
To send it or not to send it, that is the question.
so i took off the intake to put on new gaskets, and when i got the manifold off i was confused as to why it has a coolant passage in it, can anyone educate me on why it has that there?
BlackBII
Ranger Custom
Truck of Month
982
UT
I haven't worked on a 2.3 in a few years but if I recall correctly, the coolant temp sensor is in the intake manifold, where the coolant enters. One of the heater hoses is also connected to a steel pipe that wraps around the back of the head, and into the intake manifold.
Rusty Bouquet
36
Portland Oregun
Ford Ranger xl
Not much experience with the ranger head(s), but I race 2.3t's. And for those, it's partly the heater supply/return system. I've deleted them many times...
8,370
Why it is there is to heat up the intake manifold to prevent icing in colder climates, high velocity air can get very cold, and cold gasoline won't ignite with a spark, only gasoline vapor can be ignited with a spark.
Which is why all gasoline engines need to be Choked when trying to cold start them
Choke means to double or triple up on the amount of gasoline the engine gets to try and get at least 30% Vapor level in the cylinders
And the 2.3 doesn't generate a ton of heat either, so icing is a real possibility.
