ekrampitzjr
- May 28, 2021
- 1,067
- Virginia
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
Thanks to this site for carrying the instructions with clear pictures for replacing instrument panel bulbs. That helps a lot. Having the bulb number needed is another big help.
The Haynes manual says to "remove the radio", which did not seem to make sense. Now I see I just need to loosen the trim piece around the radio to be able to remove the trim around the instruments.
Haynes manuals have their weak areas...
Here's our site:
Here's our site:
How To Replace Instrument Cluster Lights - The Ranger Station
Need to change a bulb in your 1993-2011 Ford Ranger instrument cluster? This page should help you figure out how to remove the instrument cluster and change the bulbs. Tools Needed: 1/4″ 7mm socket 1/4″ 8mm socket 1/4″ Driver Bulbs … Continued
www.therangerstation.com
