Info on wiring
97FR
South Carolina
Hello Ranger family need some info on wiring up a carbureted engine I'm planning hopefully in the spring to start my conversion with a 302 crate engine and need some wiring information I'm trying to get all the info I can get before I get started
franklin2
1,758
Virginia
What truck are you starting with? What engine and transmission did it have originally? What transmission are you going to use with the 302? All the interior stock functions will remain the same?
8,370
Don't really need much on the wiring side with carb and distributor
The 302 HEI "coil on cap" distributor is bullet proof and needs one 12v key on wire, 2nd wire for tachometer if wanted, make sure to get one with Tach hookup they come with or without it
One wire for engine Temp sender
One wire for oil pressure sender
And that's it
Electric choke for carb if you want, just key on 12v and ground
AOD(not AOD-E) for automatic with overdrive from a 302, no computer control
M5OD-R2(M5R2) from 1996-2003 F-150 with 4.2l V6 for manual trans, 2wd or 4wd versions available
4.2l V6 in those years has same bell housing bolt pattern as 302/5.0l, you will need to drill out bell housing bolt holes 1/16" to fit 302s SAE bolt size, 4.2l used metric bolts
M5R2 shifter is in the same place as Rangers in those years, older truck manuals have shifter farther forward, Mustangs have it farther back but either can be used
97FR
South Carolina
I have a 97 Ranger XLT 2 wheel drive 4 cylinder 2.3 with a 5-speed Toyo koygo trans I'm going to use a T5 world class train
97FR
South Carolina
And that's it
Thank you for the info it's going to help me out a lot God bless you
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
not sure how "crazy" you're gonna get with your electrical but I tore my entire wire harness out (on a Cleveland carbureted swap), moved my Power Dist Center to the pass. side and rewired everything. My best two friends were a 1995 Ranger Electric and Vacuum manual (found on line -$25) and Walt93 here on site. Both were invaluable! Between the two and 4 months of studying and pulling wire I got her done and everything worked! Good Luck, hope you love your truck. :cool:
