Dirtman
- May 28, 2018
- 13,326
- 41N 75W
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
- Total Lift
- It's up there.
- Total Drop
- It's down there.
- Tire Size
- Round.
- My credo
- I poop in the furnace.
Duratec/extended cab trucks are super rare, and I think they're all automatics. You don't want a Duratec with an Auto trans if you've got a choice. They came with different rear gears that kill fuel economy. The auto trans is less reliable than the manual too.
A duratec/manual combo in a regular cab can tickle 30mpg. A duratec/auto trans combo is usually stuck in the 23-25mpg range. Add a few hundred extra lbs for an extended cab, and you've got a 4cyl truck that gets fuel economy in the low 20s.
The 3.0 is a boat anchor, and it's thirsty. But they are hard to kill and parts are cheap. If you want an extended cab truck, they're far more common than the 4 cylinders.
Both engines are pretty reliable and cheap to maintain. Both engines were used in multiple vehicles for many years so parts are easy to find. I've owned both and would probably choose the Duratec if all else is the same, but you can't always get exactly what you want
