e21pilot
- Jul 28, 2013
- 6
- Ford
I am looking at what I can do to improve the cooling on my 1992 4.0/auto extended cab Ranger. It generally runs cool except when towing. One thing I notice is that while the clutch fan looks to have the stock shroud around it, the fan sits almost in the open, closer to the water pump and not entirely in the circular part of the shroud as I have seen on other Ford engines. I would think this would reduce the fans ability to pull air through the radiator. I wonder if other 4.0 Rangers/Explorers are like this as well or is there a taller shroud out there or perhaps a factory clutch fan spacer that is missing on my rig?
I am also planning to add a transmission cooler in front of the radiator and want to get as much air moving through it and the radiator as the fan/shroud will allow to avoid having to add an auxiliary electric fan.
