- Jan 12, 2021
- Reaction score
- 827
- Location
- Walkerton Va 23177
- Make / Model
- Ford Bronco II
- Engine Type
- 2.9 V6
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
So to clarify the heading, the truck will run/idle/rev seemingly fine once started. But to start you have to play with the throttle like a carbureted engine. I have set timing, removed spout connector, 10 degrees advance. Run to temp, shut down, unplugged IAC started (really did not want to) and set base idle to around 700(auto trans). Shut down reconnected. Restarted and rechecked timing. Truck once warm runs good seems responsive with throttle but does not want to start on its own with out working the accelerator. I used an advanced timing light and preset 10 degrees, dialed to 0. I am going to redo that this evening hopefully and set to 10 degree's on pulley see if that makes a difference. Any suggestions appreciated.
