Rat Rod Bob
- May 2, 2020
- 0
- in my garage
- ford ranger
I have multiple pictures that I will show that shows the numbers below the exhaust on the driver side and then also just beside the water pump area. I am wanting to verify the numbers as everything that I’ve looked into doesn’t seem to be lining up with how to identify the block. Set of numbers that are just below the exhaust from what I can read is 01D93
Ones that are on The block on the flat area beside the water pump are 233 and then it has two vertical slashes then upside down it says 3D8.
From another time when I looked at it the heads had 3TM669
Any input would be greatly appreciated as I’m just trying to do some diagnostic work on the engine and it is not in the truck anymore as I receive the engine separate from a truck and do not have the Vin number that it came from. Thank you very much in advance or thoughts!
