- Oct 30, 2015
- 14
- St. Louis, MO
- Ford
- Engine Size
- 2.3L
- My credo
- Well, that didn't work. Let's try something else!
Welp. I think I broke my engine good. After 2 weeks of changing gaskets, degreasing, scrubbing, and painting, I got her fired up and she was running good. Puttered around town for a little bit just to make sure there were no problems, then took her on the highway.
Only made it about a mile when something pops and the motor dies. Trying to turn it over gets nowhere. Cranks but no start. I check fuel and spark and everything seems good. So I start looking at timing and find the distributor has spun and has the vac advance pinned against the fuel pump.
I loosen the hold down clamp bolt and turn the distributor back to roughly the correct location. It's a little tough to turn. That should have been a clue. I fire her up and she runs, but rough. Timing's off. I decide to limp her to a gas station about a mile up the road. Right as I'm pulling in, she pops and dies again. Same thing. I ask the lady at the counter if I can leave it there for the night and have my brother pick me up.
The next day I buy a reman distributor and head back down. This time I can hardly budge the distributor. I'm able to get it out. I don't see any damage to the drive gear or oil pump drive, so I line everything up and plop in the new distributor. Initial startup goes well. She's running good as long as you keep on the gas, but dies when you let off. I start fiddling with the timing to get it evened out. Just as I'm dialing it in, there's a sudden clacking sound. Sounds like there's a marble getting beat around the engine.
I immediately shut it off. I take the plugs out one by one and find the #3 cylinder's plug missing a good chunk of the porcelain around the electrode. The grounding strap does not look bent or crushed. But either way, I think my motor's probably f*cked. I don't know if the spark plug just cracked and it fell in or if I dropped a valve or something.
Are these interference motors? Meaning when the distributor turned like that, is it likely the valves kissed the cylinders? It was running VERY smooth just before it started clacking.
Either way, this might spell doom for this truck. Between the motor and the frame (rust), I don't know that it makes sense to spend any more cash on it. I might find another 1st or 2nd gen and swap the bodies. I really love the way this truck looks. I hate to see it dead.
I'm crushed right now. I put so much work into making the motor nice. I can't believe all the problems I ran into. Someone upstairs does NOT want me to drive this thing.
