wolfe1ac
- Aug 19, 2016
- 0
- Ford
Two weeks ago I had a no start, no spark issue. Running some tests I narrowed it down to the HEI control module (truck was converted to HEI before I bought it). After replacing that and the distributor cap & rotor, it still wouldn't start so I hooked up the tractor and had my dad pull me around to see if I could bump start it. It started up but would only stay running at high RPM in neutral. As soon as I backed off the gas or tried to let the clutch out, it would stall. I was thinking I got something wrong with the firing order when replacing the dizzy cap so I shifted all the wires one spot around the cap clockwise, and tried again. It appeared to turn over with a lot less effort but still no start. Tried pull starting it and if fired up but everything sounded wrong. Very low, almost non existent power, slight intermittent rattle noise, etc. I shut it down immediately and we towed it back to its parking spot. Yesterday I went out to check timing and the crankshaft wouldn't turn with a pry bar. Pulled attached the plugs and they were all fouled pretty bad. #4 was covered in oil. Hooked it back up to the tractor and tried to pull it while in gear and the rear end just drags. Seems like the engine is pretty well seized.
So now I'm wondering, what the hell did I do!? I was under the impression that to seize an engine you needed an immense amount of heat generated from friction. Oil level remains great with no appearance of contamination. Could I have buggered up a valve and gotten it wedged so badly that it's not able to move?
I paid $800 for the truck and I like it but I'm not willing to spend that same amount or more on a new engine. Is there a good source for a used 1986 2.0 OHC that would be a direct swap? Is there another year/series that wouldn't require much in the way of new parts? I know the words "cheap" and "easy" don't factor into the vocabulary of an engine swap but any ideas?
Thanks in advance. I'm going to go walk to the coffee shop.
