- Aug 6, 2007
- Reaction score
- 1,734
- Location
- Macon/Fort Valley, GA
- Make / Model
- Ford
- Engine Type
- V8
- Automatic
- 2WD / 4WD
- 4WD
I'm thinking about getting the 85 Ranger I picked up this weekend running so I can drive it until I get around to the V8 swap. I have the engine and most of the parts, but given life, work, and school, I don't know how long it'll be before I can get to the engine swap. If I can get the thing driveable I can atleast enjoy driving it while doing the suspension and other mods and maintenance it's getting. Being able to drive it will help keep interest up in the project.
Anyway the truck is a 1985 Ranger long bed 2wd with the 2.3L Lima and auto transmission. It is missing the driveshaft, which I think is probably need before I even attempt to get it running, don't want it to be dumping transmission fluid. What can I get a driveshaft from to work in this thing?
Would definitely think that one from an 83-88 Ranger with the same specs would work if I can find one. What about later models? 4wd? The wheel base didn't grown until '98, so would a shaft from a 4 cylinder auto long bed 89-97 fit?
How about an '84 2.8L manual long bed shaft? I kind of doubt it, but I've got one.
Barring finding an available driveshaft that bolts in, could I use the yokes from a manual transmission 2.8 or 2.9 to have one built? I've got both available.
Just to throw in a curve ball. Long term goal is to put an Explorer 8.8 disc axle, which I already have, in this thing to go with the V8. I'm lowering it with dream beam and 95-97 spindles, which I also already have. While doing maintenance on the suspension I intend to install the front lowering components, no point in doing the work twice. It'd be nice to go ahead with the Explorer axle at the same time to lower the back.
In the Explorer 8.8" swap article I see this:
Can I use a 90+ 2.3L long bed shaft as a bolt in with the Explorer 8.8 swap? If so it'll be easier to find, and I may just go ahead and install the Explorer axle now. I've also got a 2000 (?) Ranger 8.8 available I could install in the interim if this drive shaft is available and best option, but not ready to lower.
Sorry for million questions, this would be so much easier if I had a driveshaft compare and/or the truck was here instead of an hour away.
I'm thinking this is because the flange is different pattern? I've got an Explorer driveshaft with the right axle flange, can I attach it to the 2.3L driveshaft?
- Pre-1990 Ranger Driveshafts Will Not Bolt Directly Up To The Explorer 8.8 (Have Custom Shaft Made Or Get A 1990 Or Newer Shaft)
