Heck, I've seen some throttle bodies where the owners have ported and polished them. The for instance being the stock Lightning TB. It is a dual side-by-side TB with a big bump in the middle. I've seen them with that large bump ground away. Never causes any issues. I removed the stock TB in my Lightning and replaced it with an Accufab TB. You don't even have to tune for a different TB. just swap it and go. They say you can tune it, but you don't have to.
The TB in my 98 3.0 Ranger has been cleaned using gasoline many times. I've never had an issue with it. Use gasoline because it appears to get all carboned up, and the stuff doesn't come off easy. Gasoline works.
Failed to see this gem.
Throttle bodies contain carbon and vaporized oil from the PCV system. Carburetors get varnish from gasoline. These are two very different things to clean.
Carb cleaner is made to dissolve gasoline varnish, throttle body cleaner is made to dissolve carbon, soot, and oil.
Throttle body cleaner among other things is also sensor safe, i.e it won't leave residue on the map sensor or effect the o2 sensors. Carb cleaner can damage these sensors.
And also you can grind away at your throttle body but the ones in question here are Teflon coated (usually plastic but they did some aluminum). If that coating is removed the throttle body is trashed. Just because your throttle body is not one of those coated ones, doesn't mean you should give advice for everyone to clean them with gas or be grinding at them. Your experience is irrelevant.
Again to the OP.. Use dedicated throttle body cleaner on a throttle body and ignore bad examples.
