I caused the problem
88workcar
49
Pierre Part La.
Ranger XL
160,000 miles. I have owned it for the last 1500 miles. I started getting a small rough idle and slight hesitation on the low rpms. Truck has new wires, plugs, filters and oil. I decided to flush the coolant and put fresh in it. Last week I flushed all the rusty water (some antifreeze) out, put the "Flush" in it. Bottle said drive 60 miles for a good cleaning. This morning I removed that and put new antifreeze in it. While sitting there idling I noticed a fog coming from the exhaust. First though was I have cracked a head? I went smell it, wasn't antifreeze or oil?? so what ever..... I got my stuff and headed to work. It was running worse than before and lacked power everywhere. Got the CEL, 300, 301, 303. I got to work, parked and went look, nothing steaming or smoking from tail pipe. I let it sit for an hour, I pulled #1 and #3 plugs. Both look perfect and clean. No water in oil, no pressure (bubbles ect..) in radiator, no oil in there either. But it is still running terrible. I did lightly spray under the hood this morning to rinse some dust off of everything. Could the coil pack be doing this? I am open to any help given. If it comes to pulling heads, I'm getting a new set.
88workcar
49
Pierre Part La.
Ranger XL
After sitting in the sun all day it has corrected itself, must have wet something I shouldn't have lol.
alwaysFlOoReD
5,091
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Good. Thanks for the update.
88workcar
49
Pierre Part La.
Ranger XL
Was told today the coil pk. was what got wet and "got me" What do y'all think? Would it be a waist of money to just change it? But the truck runs better than ever now lol.
alwaysFlOoReD
5,091
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
If the coil pack is working I don't think changing it will help. Did you use di-electric grease on the boots (both ends) when you put the wires on? Not only does it help removing the wires down the road but it helps seal out water. Also check your wires for signs of heat or cracking.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Wait until it's dark outside... grab a spray bottle with water. Spray down the secondary ignition. You will see what is causing it...
88workcar
49
Pierre Part La.
Ranger XL
Wires are new, I used the grease.
Uncle, I'm scared to press my luck lol
alwaysFlOoReD
5,091
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm on my phone and can't see what year and engine you have. Also try what uncle gump suggested. A spray bottle like what you would use for cleaning windows (Windex). Its just a mist of water and if there is electricity going where it shouldn't the mist will help you see it. Make sure its pretty dark where you do this.
