I bought a High Rider...
Junk Collector
Forum Moderator
1,337
Rapid City SD
OK... tomorrow is the day... I think! As long as the wind isn't blowing hard tomorrow evening, I'll be painting. Fingers crossed. I'm happy enough with my primer.
This is paint booth v4.0 - 1.0 was nothing and overspray everwhere, 2.0 was covering things up with sheets and some plastic on the floor with a box fan surrounded by cardboard, 3.0 was a three sided plastic enclosure in the same spot with this fan. I don't think the back side will be necessary nor did it help much so I left it open and made the walls longer.
This fan works pretty well. Obviously it could be improved... but with a north window open and the fan sucking out the south, it moves plenty of air but the wind can affect it badly. Kinda ghetto but I'm not sure how I could improve without a major redesign.
Rock Auto 5% Discount Code: DE2235E7692E8C: July 5th, 2021
Junk Collector
Forum Moderator
1,337
Rapid City SD
Hate to say this but I have to go several steps backward.
I shot my first coat of base on Saturday night and refilled my gun... went back to shoot another coat and saw this disaster.
It's basically all over, every section of the cab has at least some of this going on, the back, rear roof and driver's side B pillar being the worst. It peeled up everything down to bare metal.
I talked to my buddy that paints for a living and he said I most likely did not use enough primer and then sanded through what little primer was there when I scuffed it, and the solvents in my base coat reacted with the etch primer I had below everything else. His process is to use etch primer, then 4-5 coats of 2k primer, then sand, and prime again if needed then sealer then base coat, clear. Mine was etch, 1 coat of 2k, sand, another coat of 2k, sand, base, clear... apparently not right but who knows why it didn't bite me before this.
His advise was to use lacquer thinner on a rag to remove the bubbled spots, wet sand it smooth, etch/spot prime and then scuff the whole thing and shoot sealer directly over it all and then follow that up with base/clear. Any input?
Kind of embarrassing to post this but what I was doing was working fine for a hood, two fenders, and a door....
Forum Moderator
6,274
SW Iowa
Any input?
This is the kind of thing that keeps a feller up at night when he gets to thinking about painting his truck.
It happens to everybody, you get to learn something about something new now! :icon_thumby:
BlackBII
Ranger Custom
473
UT
Oh damn dude that sucks. I had to re-do my fenders because of some huge runs so I know what it's like to have everything perfect and then it goes to shit.
What kind of paint are you using? I sanded through to my etch primer as well but I was fortunate to not have this happen. I used a urethane paint
Junk Collector
Forum Moderator
1,337
Rapid City SD
I had visions of matches and the 5 gallon pail of kerosene sitting in the corner... but I don't need an arson conviction...
Redoing things doesn't bother me much, I have done a lot of that, but in this case it's like $100 down the drain every time I mess something up.
I used:
Impact IMP130 gray etch primer
Nason SelectPrime 421-19 2k Primer
TCP Global (Restoration Shop) Dark Midnight Blue Pearl Urethane Basecoat
Restoration Shop KC2020 Ultra Flow Urethane Clear
Should be all compatible stuff... I feel like maybe I just had a lot of sand through to the etch primer that I couldn't see. My buddy said that I really need 4-5 coats of buildup before I even consider sanding the primer or I will have stuff like this happen.
I guess I am fortunate that since it's just the base coat, I can basically wipe it off with a rag soaked in lacquer thinner instead of doing a lot of sanding.
BlackBII
Ranger Custom
473
UT
I used Restoration Shop's Urethane as well, with SpeedoKote 2K Urethane primer.
I looked at the data sheets for all that and yeah it should all be compatible. I've seen wrinkles like that when using enamel over a lacquer or something.
Hopefully round 2 goes better! I guess with 4-5 coats you'll be able to block it all until it's nice and flat (y)
Junk Collector
Forum Moderator
1,337
Rapid City SD
I'm going to try a different primer. I ordered a gallon of U-Pol UP2253 2k urethane... it is a LOT cheaper than Nason, $84 shipped with a quart of hardener and has a lot of positive reviews. I was spending $67/quart w/ hardener for the Nason primer. I ordered another gallon of base coat too... an expensive bummer, but I'm running low, and I don't think a quart would have done my whole box plus the hood if I decide to redo that.
I just Googled that SpeedoKote stuff, looks like it's about the same price as the U-Pol I ordered. Maybe I'll try that next time.
Good to hear that there is other positive feedback on TCP products... I don't fault their product here at all, I'm sure it's an issue with my process.
BlackBII
Ranger Custom
473
UT
That's usually how it goes, especially with paint. I blamed my gun at first when I had a bunch of runs, but I knew it was my own fault; too slow, gun not setup right, etc
Good luck this time around!
