I-Beam to Radius arm Bolt size/length
ratdude747
22
Madison, IN
215/70R15
This weekend I will be attempting to replace the radius arms on my 1995 RWD (the bushings are failing and one arm has a rust hole). Based on past experience, I imagine that the long bolts that go through the beam, arm, and spring retainer (with 2 nuts) will be rusted away and may need to cut off (if I can't get it with a wrench and socket/breaker bar and a MAPP torch).
However, outside of some overpriced part kits on ebay (with arms), I can't find replacement hardware anywhere nor can I find a size/spec. I'd like to have the parts in-hand before I begin the work. Also, I'm on the road for work (in a rental van) so I can't measure it right now.
If somebody could tell me the sizes of said hardware (Class 10/ grade 8, I know), that would be great. Or somebody selling the bolts and nuts as a kit that I can order.
BlackBII
Ranger Custom
Truck of Month
982
UT
EDIT: My bad. RWD is different and only uses one long bolt. Sorry I am of no help.
The following is for the 4x4 beams/radius arms.
You can buy new bolts here, though they are not cheap. I Beam Bolt
The top bolt is a two part bolt; the radius arm is bolted down with the 3/4-10 part, and the coil spring uses the 5/8 - 11 part. The lower beam bolt is just a regular 3/4-10 bolt.
Bird76Mojo
1,265
IL
BlackBII
Ranger Custom
Truck of Month
982
UT
Yikes. $27 for one bolt.
You'll probably have better luck pulling the bolt out and going into Fastenal or ACE Hardware and getting one of similar length.
Bird76Mojo
1,265
IL
I've never pulled one out that was actually bad. If you squirt them enough, several times, a few days prior to removal, you shouldn't have any problems. You live in a similar location to me as far as rust and salted roads, etc.
If it's not a pressing issue, I may have a couple spares here in a few days. I'm doing a beam swap right now.
ratdude747
22
Madison, IN
215/70R15
I'll look into it. On my last ranger one was fine while the other was a pile of powdered rust under the spring "cup".
Locotomb
62
Puyallup, WA
2.3l
6inch custom fab lift/86
Bagged 3 inch custom drop beams 88/89 Custom triangulated and step notched rear
35/12.5/r18
Everything looks better lower
I know my first generation bolt is 3/4x8” with a 1-1/8” hex head. Cost me $17 apiece at Fastnel for a 9” bolt.not sure if the trucks are the same but the shock lower mount was 18mm both bolt and nut, while the top is 15 and 18mm.
ratdude747
22
Madison, IN
215/70R15
Update: I have tomorrow through Sunday off, so I went ahead and pulled it apart this evening. Or as far as removing everything but the through bolt and the end nut/bushings. Good news: both nut and bolt sets are in very good shape. Not the powdered mess I had last time.
